M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
2004 mercedes cl600 stuck in park, need your advice
Old May 20, 2020 | 04:11 PM
biker349's Avatar
cl600
hi, shifter is stuck in park. brake lights are working. car starts up so i believe this eliminates the ignition switch as being the problem. we have used a rubber mallet and pounded on the top of the shift handle with ignition on and foot on brake and also with . car running and the shift lever will not release. we removed the bevel that shows the various shift settings, ie. park neutral drive, etc. and tried putting a small screwdriver down the space and trying many positions and angles to try and find the lever that releases the neutral safety switch without any success. i know that some of you were able to cut the lever for the neutral safety switch without removing the console.can you please explain the way to do this. my mechanic has all types of grinding tools and cutting tools and is certified. your help would be greatly appreciated. please respond a.s.a.p. since this is my only car and daily driver.
thank you for any help and advice.
the best, biker349
Old May 22, 2020 | 07:48 PM
biker349's Avatar
cl600
mechanic got it fixed. after many tries he used a heavy hammer on top of the floor shifter and it broke lose. found the plastic neutral safety switch was broken in half and removed it. problem solved.
