Hi all,
Does anyone know what can cause a misfire during idle only, or that can be provoked by poking the throttle pedal and letting the car roll back to idle (it then stumbles a bit when it hits idle rpm).
Codes aren't being set but they can be felt, and are detected by the fault counter. One cylinder (nr. 5) is notably worse than other but it occurs across about 9-10 cylinders. Cylinder 5 has read up to 5 faults on the counter before it resets.
When being driven under any conditions there is nothing registered on the fault counter under any driving style. This only happens at idle.
Any ideas?
Any ideas?
Fried Chicken
close
- Join DateDec 2007
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2005 S500 Designo
Liked:224 Times in 184 Posts
See cowboyt’s thread.
Don’t go on a wild goose chase. Take your time to find out exactly what’s wrong and then fix it.
Well I'm pretty astonished. Reinstalled the original style throttle body gasket and the misfire on cylinder 5 has gone. Nothing looked wrong with the "updated" throttle body gasket when I pulled it off. It seems that perhaps the M275 gasket being smaller than the throttle body opening has some significance.
