M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
2004 mercedes cl 600 extremely low battery drain over night in cold weather
Old Dec 3, 2020 | 03:43 PM
biker349's Avatar
cl600
Question 2004 mercedes cl 600 extremely low battery drain over night in cold weather
i have an extremely low current draw that is draining battery overnight. i still have just enough power to start car, but it is close. car regains full power after about 4 minutes of driving. had battery and alternator tested and both checked out good. this only causes problems in cold weather. does anyone have a clue as to what i should check that is causing this low battery state any help is appreciated. all systems are functional.
thank you, harv.
2004 mercedes cl600
Old Jan 2, 2021 | 06:16 PM
BenzNinja's Avatar
Former Vendor
what is the drain you measured ? and how long did you measure
some modules turn off first, then turn on every XXX minutes with peaks
here the best and cheap way to measure
you can safe sitting there by using a camera or your phone recording the screen
then later rewind
buy this PeakTech 4250
buy a Mini Fuse Breakout Extension
put a 20amp fuse on it
hook the PeakTech 4250 up to any voltmeter
replace any suspected fuse with the Mini Fuse Breakout Extension
put the PeakTech 4250 around the Mini Fuse Breakout Extension wire
let the car go asleep
measure the draw
total draw asleep at battery should not exceed 65 milliamps
Old Jan 2, 2021 | 06:19 PM
BenzNinja's Avatar
Former Vendor
most suspect fuses are:
front seat modules
cd charger
command
PSE
trunk lid pump
6 Father's Day Gift Ideas Your AMG Loving Dad Will Cherish
Slideshow: Six Father's Day gift ideas your AMG loving dad will cherish.
By | 2026-06-03 16:34:48
