Where is the Oil Level Sensor for replacement
Do I need to remove the lower oil pan? (I.e is that where it is?) If yes, does anyone have the part number for the lower oil pan gasket?
Thank you.
EDIT: I bought and originally mentioned the wrong part number ((# A0009056201). The correct oil sensor part number for a M275 is 2759050000 and costs about $110 from various vendors.
Yes, the lower oil pan is a bit difficult to remove as it is factory glued with RTV. I used a metal gasket scrapper and pounded it in with a mallet to get it started. That did put a scratch into the upper oil pan, but the new RTV will easily seal that. I then sprayed the surfaces with gasket remover and used a rubber bristle disk on a drill to clean the surfaces.
