M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Cooler thermostat?
Old Oct 18, 2024 | 12:46 AM
Fried Chicken's Avatar
2005 S500 Designo
Cooler thermostat?
These engines run hot, even for mercedes. The v8 runs significantly cooler than the V12. They did this for emissions reasons, but it's not good for the engine.
Has anyone switched to a cooler thermostat? Where would one find one that fits?
Old Oct 23, 2024 | 07:02 AM
tim687's Avatar
CL 600 '00 5.8L V12
How hot does it run? Mine stays at 97 degrees C in traffic and at around 80 on the highway
Old Oct 23, 2024 | 04:37 PM
pjw1967's Avatar
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (sold...sniff)
Usually a "cooler" thermostat does nothing for the high end. Yes, a 160 degree stat will open earlier than a 180 stat. But once they are both wide open, they don't do anything to lower the operating temp.
Old Oct 26, 2024 | 12:19 AM
JohnLane's Avatar
222 S-65
You sure it isn’t good for the engine to run at 190?
The engineers have have been at it a long time.
At 190 more fuel gets burned in the cylinder. Higher pressures. More torque. Less emissions.
Everything about the engine has been designed around running at 190.
There is plenty capacity in the radiator.
We ran lower temp thermostats in crappy old junk running carburetors with iffy cooling systems.
