Hot start issues on M275
I found that gasoline without Ethanol was much less likely to do the hot start blub-blub-blub-blub-stall thing. Then restart and run fine. Over the years I have encountered cars available for sale that the dealer got to buy back for this very issue. Branded title= lower pricing on that used car.
Updating the software forces higher fuel pressure and eliminates the issue.
As others have mentioned this is a fuel problem such as fuel boiling in the fuel rail.
Here are my suggestions:
1. Take off the engine cover and hang it in the garage or living room. Sure they look pretty but engines cool better with them all off. IMHO the fuel rail temperature is greatly affected by the engine cover.
2. Buy a cheap fuel pressure gauge and screw it onto the front of the fuel rail. If not familiar, search Amazon for "BETOOLL 0-140PSI Fuel Injector Injection Pump Pressure Tester" and pay $30. Or rent one free from the local auto parts store.
The fuel pressure for the M275 is around 56 psi. (AI says "54-61 psi").
If the pressure is out of that range, you may have a problem with the pressure sensor, the fuel pump control module or the fuel pump itself. The pressure sensor is easy to replace, the other parts not so easy.
If you can report the fuel pressure to us, we will try to guide you further.
FYI - I has a stubborn "misfire code" problem. Checked the fuel pressure and it was 110 psi. Replaced the pressure sensor and that corrected all.
I fill up with premium 91 octane here in California. The car is tuned by Weistech, but for 91 as well. I'm going to take the engine cover off and see how the car behaves tomorrow.
@mrvedit, what should I try next? Would you happen to have the Mercedes spec for fuel pressure loss?
After sitting for 3 days: 0 psi
Ignition on: 47 psi - built within a second or so
Ignition on for 5 mins: 41 psi
Engine on: 57 psi
Engine off: 50 psi
Engine off 5 mins: 48 psi
Engine off 30 mins: 43 psi
By "same thing here" do you mean engine starts fine but then dies shortly thereafter? Is engine cold or hot when started?
If easy to replicate, have someone monitor fuel pressure when it stalls. (I guess it could remain at 55 psi even if air got in the system due to heat soak, but if it indeed drops low we have usable info.)
No idea if Amazon is filled with counterfeit Bosch sensors too, but don't see why not. For auto parts on Amazon I always make sure the seller is Amazon itself and not something like CheapoAutoParts and even that is no guarantee.
In short, maybe try another crank sensor, this time from the MB dealer.
Engine on: 57 psi
Engine off: 50 psi
What I mean by “same thing here” is that the more I drive the car throughout the day and the hotter the motor gets, the more it starts stumbling on startup—and eventually it won’t start at all toward the end of the day. I put some miles on it yesterday, and even though I couldn’t get it to completely not start, I did get it to misfire on startup.
What I did next was relieve the fuel pressure through the nipple at the fuel rail, and I’ve got to tell you—I’ve never seen a fuel line purge like that for as long as it did. There was a ton of vapor that purged along with the fuel, which confirms the fuel is boiling in the rail. This is exactly how old carbureted cars behave when the fuel line runs too close to the exhaust—classic vapor lock. After that, I tried starting it again, and it fired right up, just like it does when the car is cold
@JohnLane mentioned Mercedes had a solution involving a software update, so I reached out to Paul at BenzNinja. He was familiar with M275 issues like this and said MBZ addressed it with an ECU update, so we went ahead and did that today. Unfortunately, the update wiped out my Wistec tune, so I sent the ECU back to have it reflashed.
Once the car is back on the road next week, I’ll report back on how the MBZ software update affects things on my end.
If, for some reason, this doesn't fix the issue, I'm going back to my hotrod roots and already thinking about a fuel purge system that vents through a charcoal fuel canister. More to come.
Anton no doubt the software update alters fuel pressure.... likely just as it is turned off. Or are they stopping fuel from returning to the tank (to hold rest pressure high enough to keep it from boiling) via the pump?
It's not just a long start. Sometimes the car will fire then die. Usually, it'll fire up just fine on the second start attempt.
Updating the software helped mine.
