2003 MERCEDES-BENZ C 230K SPORT COUPE From AZ no rust. (Shipped to Michigan in 2020)
2003 Mercedes-Benz C230
  • 2003 Mercedes-Benz C230 - 2003 MERCEDES-BENZ C 230K SPORT COUPE From AZ no rust. (Shipped to Michigan in 2020) - Used - VIN WDBRN40J43A411259 - 60,080 Miles - 4 cyl - 2WD - Manual - Coupe - Black - Bloomfield Hills, MI 48304, United States
    $3,000
    • OBO
  • Location Bloomfield Hills, MI, 48304, USA
  • VIN WDBRN40J43A411259
  • Mileage 60,080
  • Engine 4 cyl
  • Drive Type 2WD
  • Transmission Manual
  • Vehicle Type Coupe
  • Exterior Color Black
Inherited car. Car sat for a long time.
Had full inspection by garage prior to moving; was running when delivered from AZ.
Engine is very clean. Performance and handling was outstanding. Braking good.
Timing belt/timing chain presumed slipped or broken. Unsure of engine condition internally as a result.
Recommended by garage (specializing in German import cars) that an enthusiast may want the vehicle as a project.
Everyone says what a shame as the vehicle is in outstanding condition considering its age.
Selling car as-is. No guarantees. Would need to be towed (does not run).
  • Driver side speaker panel has some damage, but not sure from what. Should be easy to replace if this bothers you.
  • New battery in Summer 2020. Interior detail at same time. Floormat condition ok.
  • Leather in great condition, except indentation in backseat - again, minor. No rips, tears, or stains that we could see.
  • Newer tires with little wear.
Cost to put a new engine in if needed would be approx $2.5k if you can't do the work yourself.
Old Oct 5, 2020 | 01:49 PM
drb930's Avatar
2005 C230 Sport Coupe
There's a guy on here looking for a manual.
Bet it was downshifted into the wrong gear, probably bent the valves.
