:: ECS Tuning :: 722.6 Transmission Kits
Old Apr 27, 2016 | 03:35 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Starting At – $16.02*
A common part failure on Mercedes-Benz 722.6xx automatic transmissions, the wiring harness connector can begin to leak transmission fluid, eventually draining to the transmission control module and causing expensive damage.
ECS Tuning offers a brand new Wiring Harness Connector Kit, complete with new o-rings, dipstick tube cap lock pin and a quart of fluid to make installation a quick and easy process.
Fits:
SLK230 (1999-2004)
SLK320 (2001-2004)
SLK32 AMG (2002-2004)
*Price subject to change.
Old Apr 28, 2016 | 04:34 PM
ECSTuning's Avatar
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Wiring Connector Kit For Your R129 SL-Class
Fits:
SL320 (1997)
SL500 (1996-2002)
SL600 (1996-2002)
Old May 6, 2016 | 04:23 PM
ECSTuning's Avatar
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Service Kits For Your R230 SL-Class
Starting At – $81.41*
Your Mercedes-Benz transmission is a collection of parts that must each be functionally sound for the gearbox to do its job.
It follows then, logically, that when attending to a particular transmission issue, the strength of the weakest part determines the end quality of the system.
For this reason, ECS offers several complete Transmission Service Kits for your Mercedes.
Choose from premium ECS-assembled and genuine OEM packages - each including Automatic Transmission Fluid, Filter, Oil Pan Drain Plug and Sealing Washer, Dipstick Tube Cap Lock Pin, and Pan Gasket.
Fits:
SL500 (2003)
SL600 (2004-2009)
SL55 AMG (2003-2008)
SL65 AMG (2005-2009)
