MB SUVs, Trucks, Vans, Diesels Vendor Classfieds
Headlight Conversion from 2007 Mercedes Sprinter to 2014 Lights? HELP!!!!
Old Jan 17, 2020 | 03:27 PM
Hayden Lee's Avatar
Mercedes Sprinter 2007
Can anyone help, I am converting a 2007 Mercedes sprinter to a facelift and I need to know about the wiring harness for the headlights because it appears to be the same plug but different wiring, is there a conversion that anyone knows of? Or if anything can be bought. Also does anyone know the sequence of wiring for the headlights, the headlights I am using are from a 2014 Mercedes sprinter.
Old Mar 23, 2020 | 05:19 PM
49TCV's Avatar
sprinter
Sprinter headlights
Hi
you created a post recently about the upgrade , I’ve just bought a 13 plate and was wondering if you’d found any information about the wiring plan ?
if you have it’d be great if you could share as like you I’m struggling
many thanks neil
Old Jan 2, 2022 | 03:32 PM
tanny8970's Avatar
lamborghini urus
Help facelift conversion
hi did you manage to get the headlights wired? I’m doing the same and stuck on how the headlights wire up if you have any information it be appreciated
Old Jan 2, 2022 | 03:34 PM
tanny8970's Avatar
lamborghini urus
Originally Posted by 49TCV
Hi
many thanks neil
hey did you find any information in regards to facelift headlamp diagram of wiring
Old Jan 2, 2022 | 05:57 PM
49TCV's Avatar
sprinter
Headlight wiring
hi
eventu I worked out that the different wiring is just the feed for the Drl
most people ignore the use of the drl as it’s not required nor a legal requirement for the mot as they weren’t originally fitted and are not a requirement for the year.
however I took an ignition switched feed and bought generic drl relay from eBay and now work and 1/2 power to the drl when the headlights are on
hope that helps
Old Apr 10, 2024 | 05:39 PM
Vanguy29's Avatar
2010 Mercedes sprinter 906
Sprinter conversion
Did any of you guys manage to successfully rewire the headlights in the end? If so how was it done? I've bought the connectors with some of the harness still connected for the 2014 onwards headlights but I'm still stuck with diagrams. Do you guys have any from your conversion?
