99 c230 -36 degrees showing
I assume you're talking about the outside temperature display. If it stays that way all the time, I would suspect the outside temp sensor, or it's wiring, has failed. Maybe it came unplugged or something. If the display changes but does so in a way that defies logic, i.e. going down when it gets warmer, varying wildly for no apparent reason, etc., then I would suspect the sensor itself is faulty.
