Harmonic Balancer Recall: Key Points
Old May 27, 2005 | 08:05 PM
Gregs210's Avatar
2001 E320 (210.065), Brilliant Silver; 2002 Ducati ST-2, Arrest-me Red
Exclamation Harmonic Balancer Recall: Key Points
This is bouncing around in some of the forums, but I think this is the right place for it since it affects several different models. MB is conducting an inspection and replacement campaign for harmonic balancers (HB) in a few hundred thousand cars. It's campaign number 2005020003.
The vehicles included are in the model ears with 1998 through 2001.
Models are:
163, 202, 208, and 210 with the 112 engine.
129, 163, 202, 208, 210, 215, 220 with the 113 engine.
Also included is the 2001 model year 170 with the 112 engine.
Don't go crazy, folks, it was a supplier problem and just because your car fits that model, engine and year does NOT mean you have a defective HB. You can check it yourself for peace of mind -- I did.
The HB is located immediately behind the large pulley at the bottom-front-middle of your engine. The part number is stamped on the outer arc of the HB, so if the crank is in the proper position it's VERY easy to see. You may have to start and stop your engine several times to get it to rotate to the correct position, obviously don't be looking around under there while the engine is running.
Once you locate the number see if it is one of the two below, if not, breathe a sigh of relief.
The only two part numbers affected are:
A112.035.00.00
and
A112.035.06.00
If you have that part number on your HB and MB knows that you own the car, they'll send you a letter or if you're in good with your dealer, call them to see if you can schedule an appointment. The repair is at no cost to you. If you point out that you've already inspected it and your HB bears the part numbers included in the recall, that will probably gain you a couple of brownie points.
Take care and enjoy the ride,
Greg
Old Jan 4, 2025 | 04:34 AM
Isabella Anders's Avatar
Car
It's great to see that people are discussing this recall issue! For anyone interested in checking out more about potential issues or related cases, you can also explore resources for arrest records, police cases, and more in Virginia through Arrests info VA. Whether you're looking into VA court records or Virginia crime data, there’s a wealth of information available to keep you informed on various public records.
