o2 sensor code/check engine light comes on and goes off on new sensors, WHY!?
w210 e55
Why would my check engine light go on and create O2 codes on new sensors?
I replaced them and had codes. We cleared them but it came back right away and now a day later it stopped?
Is this an issue or should I consider it resolved
1999 E55
1999 E55
Could be for any number of reasons. An O2 sensor code does not necessarily mean the O2 sensor is faulty. All it means is that the computer 'saw' a problem on the O2 sensor circuit. Could be faulty wiring, leaky injectors, or even a faulty-out-of-the-box O2 sensor.
Your car has OBD II diagnostics. Knowing the exact O2 sensor code is important for figuring out which way to approach the repair. Further, an OBD II code requires three drive-cycles to clear a code once repairs are made.
w210 e55
Thanks for the quick reply. What is a drive cycle considered? Starting and shutting down the car? Or is there a time factor involved.
I am going to check the exact code again and will post it.
There is time factor, warm-up and cool-down, driving conditions under which the component is tested, and it varies for different systems. For an oxygen sensor, I suspect that three seperate trips where the engine is allowed to cool off between said trips will do the trick.
w210 e55
Doesn't sound like it, and no black marks on any of the flanges or pipes. I have one brand new cat. All looks pretty tight and right on the exhaust.
Any other ideas?
Any other ideas?
