2K3 SL500 turn signal change
Old Jun 12, 2005 | 07:03 PM
fizzle's Avatar
09 ML320, 07 BMW 335i, 03 SL500
i know this is probably easier than it seems, but i tried to take out the bulb thought i had it and it was the one below but its quite odd because the socket i pulled out seems like it should be in the spot where the turn signal is. i also tried to take out the headlight assembly completely. i took two bolts out, and nothing. i cannot figure this out. please help. thanks
Old Jun 14, 2005 | 10:00 PM
fizzle's Avatar
cmon tech you cant figure out anything?
Old Jun 17, 2005 | 06:45 PM
mercedestech2's Avatar
2000 BMW M5
Many of the sockets in the headlamp assembly look the same. In order to remove the headlamp on a R230 you must at least partially remove the front bumper to access the other headlamp assembly screws.
Old Jun 19, 2005 | 08:16 PM
fizzle's Avatar
so i have to remove the bumper on the passenger side slightly to remove? hmm just to change the light that is kinda odd. i think it would be easier to remove the part of the engine that is in the way. is there another way to replace this bulb?
Old Jun 19, 2005 | 08:19 PM
2000 BMW M5
That is to remove the headlamp assembly you refered to. In order to change the turn signal bulb, you remove the socket and replace. If you can't find the socket or are unable to perform this task in under 5 minutes, you might want to take it in to the dealer.
