Does my roof motor buzz?
Old Jun 19, 2005 | 04:13 AM
user244075's Avatar
1996 E320
I have a '96 E320. There is a buzzing (or small motor whirling) sound coming from the interior lights. It happened a while ago and went away, I think when the temperature changed. Anyway it came back. If I remember from last time when I took out the light bulbs I still heard it. I assume it is the sun roof motor behind the lights? Can anyone confirm that? I hear the noise even after the key in the ignition is removed for an extra ten seconds. How do I fix the buzzing or troubleshoot it to find out what is going on? Thanks.
Old Jun 19, 2005 | 09:05 AM
mercedestech2's Avatar
2000 BMW M5
In the overhead control panel there should be an in car temp sensor. For this temp sensor to work it has an aspirator motor. Essentially a small fan that can make some noise. Look at the control panel, there should be a portion that has slits cut in it. Listen at that point and that may lead you in the right direction.
Old Jun 22, 2005 | 02:22 AM
user244075's Avatar
1996 E320
Thank you very much. That was the exact problem. The bearings on the little fan motor were making noise. I had to remove the whole control panel assembly and then remove the motor. Las Vegas Fletcher Jones Mercedes cost me $100.99 for the little freakin part that couldn't cost half that. I'm feelin pretty screwed in the wallet.
Old Jun 22, 2005 | 07:44 AM
2000 BMW M5
Sorry it cost so much, just happy you could find your noise.
Old Dec 18, 2011 | 05:48 PM
A.T.C.'s Avatar
1998 E320 Wagon
do you have the part # for the part? Does anyony have any more information on this fix?
