Please help. Radiator hose problem
Got a 98 Clk320 and when driving home yesterday, the "Coolant level" error shows up on the display. I noticed the temperature starting to climb beyond the normal operating temp so I pulled over.
I opened the hood and there was coolant all over the place. It looks like the upper radiator hose was torn near the radiator.
How hard is it to replace this hose? Do you I need to do anything special or require any special tools? I'm assuming I just replace the hose, buy coolant from the dealer, and put in a 50-50 mixture of coolant and water.
Am I missing anything? Any help would be greatly appreciated.
Thanks in advance.
J
I hope the engine is OK. The temp reached all the way to the top but I shut off the car and haven't turned it on since.
Thanks again.
As for the overheat, your engine has lots of aluminum and that does not react well to an overheat. Its a crap shoot and you really do not know untill you get it running again. Remember, the engine atually gets hotter after you shut it off. Good luck!!
