Oil psi always on 3 bar when car is on. (W124 3.0)
'92 300CE, '93 300ZX Twin Turbo
Just got this car ('92 300CE w/104k miles) and can't imagine that this is a correct indication. Should I just shotgun the sending unit or is there some other typical problem to check?
TIA,
Dan
TIA,
Dan
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Put a direct reading pressure gage on the engine and see if its different than the panel gage. It can be installed where the pressure sender is installed
95 E320 Cabriolet, 108K
It should read something less than 3 bar, especially at idle after the car has been run for a while. It sounds like the needle is pinned for some reason... bad oil pressure sender?.... short somewhere?
Originally Posted by MBTECH2003
Could just be a loose connector, they read full pressure when the circuit is essentially an open, and no pressure when shorted out or with low resistance.
TIA,
Dan
