Help w/ OBDII code P1341 - '94 C220
Old 10-28-2005, 05:23 PM
mr_man12's Avatar
1994 C220
So my check engine light came on recently, I went out and got an OBDII scanner and the code is P1341. I can't find any mercedes OBDII code listings for this #.
1994 C220 I4 engine, 109k miles no mods. Idle was a little squirrely before the light came on, and a few days before this I had to replace a fuel hose that was leaking all over the road. Car is driving fine though, MPG is the same.
Old 05-17-2011, 08:28 PM
BenzWVU's Avatar
1995 C280
I just got that code also. its for the camshaft sensor. either replace sensor, check for loose connections, or oil could be really dirty. your car is running on default settings with that sensor not working, so it will run a little rougher.
Quick Reply: Help w/ OBDII code P1341 - '94 C220
