ml320 sunroof trouble
98 ML320 03 LS430
I have a 98 ml320 and the sunroof only opens 3/4 when you push the button once,if i hold the button it opens all the way,i tried to resync like the manual says and still no luck,same with closing it,does anyone have any tips on how to get the sunroof to open and close all the way with one push of the button.
Do you mean that when you close it (push to close) it only closes partially? I'm not positive about that, he might be right. That might be the way that it is.
The only way that I know how to reset it (or any window) is hit the button to open it, then when fully opened, press and hold the button to "open" for 7 seconds. The close it and push up to 'ven't it........hold that for 7 seconds. Turn the ignition off, then on............it should work fine.
