2003 s500 air suspension issues
thanks for any and all help
daniel
daniel
This is going by experience. The only way to be sure is to have it diagnosed and checked for leaks throughout the entire airmatic system, as there are other points for leakage.
If the struts are leaking, the only remedy is to replace them.
You should have it repaired asap as the increased running of the airmatic pump will wear it out and cause it to fail.
Using air for suspension is one of the silliest ideas, imo. Too many points for failure and expensive to repair.
