Whirring sound from C230 power steering pump at low speed - should I worry?
Old Aug 2, 2002 | 06:50 PM
o2bsurreal's Avatar
C230 Sport Coupe
My '02 C230's steering pump is making a whirring noise at low speed (parking lot maneuvers) after it is started. After turning the wheel lock to lock, it seems to disappear. I just started noticing it about a week ago. The steering seems to be fine as far as the way it feels. I tried to find where to check the steering fluid, but I could not find it under the hood or get directions from the manual. I may have missed it, but in any case, it just came back from its Schedule B service so I would think that they would have checked all fluids. Does anyone know how I can double check them, and has this happened to anyone else?
Old Aug 3, 2002 | 12:44 AM
Lynn's Avatar
The power steering pump is under the same cover as the oil filter on the driver's side of the engine. I would expect that if you remove the cover you would have access to the power steering pump reservoir. I'm not 100% certain that is the location of the reservoir, but the power steering line all lead to that location
