Both rear cigarette lighters no power
Old Feb 24, 2006 | 08:00 AM
dhs9's Avatar
I have a 2000 S500 and when I pushed down both rear lighters they did not pop back up with the engine on. I then pryed them out took a multimeter and found good ground but no 12v on either. THe strange thing is the fuses one for each lighter are good and hte other things on the same circuit work. Any suggestions as to why the lighters are inop. They are on totally seperate fuses.
Old Feb 24, 2006 | 03:52 PM
Hightower's Avatar
have you checked the 12v feed both sides of the fuse? and at the base of the lighter where the plug attaches? if you plug a cooler or anything like that into these it can sometimes spread the legs inside and they just need bending back in slightly with a screwdriver and the ignition off.
Old Feb 25, 2006 | 09:04 AM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Check that you haven't disabled your rear power windows using the center button beside the driver. Disabling the rear windows also disables the rear cigarette lighters.
Old Mar 5, 2006 | 02:47 PM
D_TECH's Avatar
werd
