Brake Calipers
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I have a W209 CLK500. Anyone know how to remove the front calipers and rotors...can someone please give me a step by step?
2018 GLC300 4Matic; 2005 C55; 2003 360 Modena
Thanks![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
Remove bolts by slightly losing one and then the other, then remove both.
Pull back the caliper and hang it using something like string that won't mark the caliper. Don't stress the brake line or fittings.
I believe there is a philips set screw for the rotor, remove.
Slide off disc.
Clean mating surfaces, install new (cleaned if necessary) rotor.
Set philips screw.
Install caliper.
Install bolts - torque, but tighten both in stages, don't fully tighten one before the other.
Install wheel - torgue. (again in stages).
Originally Posted by kjb55
I'm not sure if this will be detail enough... but here goes. Fixed type calipers will have two mounting bolts on the inside of the caliper.
Slide off disc.
Set philips screw.
Install caliper.
Slide off disc.
Set philips screw.
Install caliper.
