OBD code P0170 fix
OBD code P0170 fix
I have had a reoccurring Check engine light and only one code stored. P0170
I have the complete list of OBD II codes. I was told that I had to replace the Mass airflow sensor. I argued with the dealer that if the MAS was bad, the code will read P0171. (as per my list) P0170 indicates a lean mix caused by the intake tract.) Loose hose clamps, cracks in the ducting will cause this. So will a dirty MAS.
So.. I cleaned the MAS. I looked at electrical contact cleaners to find one that dries residue free. (VERY IMPORTANT!!) I took the MAS out of the intake ducting and sprayed the contact cleaner on the elements (2 very thin wires) of the MAS. I sprayed from both directions. The tiny wires went from gray to shiny silver. I let it airdry for 10 minutes while I diconnected the battery to reset the codes.
Anyone who has used a K&N or any cloth/ oil airfilter, will get this often. Due to atomized oil collecting on the wires of the MAS.
I reinstalled the MAS and started up the car. It stumbled for a few seconds, then cleared up. This was a week ago, and the light has not come back on.
No not necessarily. Just now you'll have a fix for the code caused by the oil on the wires. I know of someone that had to buy an MAS because of it. Seems he didn't need to after all.
Happy motoring all!
Happy motoring all!
Originally Posted by lkchris
Be a good thing to sh*tcan the K&N.
1983 300sd
Happy motoring all!
Happy motoring all!
