AC not cold at all
Also, the gas contains the lubricant for the compressor - and the lubricant tends to go when the gas leaks/finishes. So, I wouldnt run the compressor until the gas is checked as you really don't want a knackered compressor ..
R
Quick check for you to do for now is turn the a/c on and see if the a/c lines are ; the larger diameter should be cold and the other one should be warm or hot.
