AC problem
When I was finished, I noticed that a couple of the vacuum lines got disconnected from the 'harness' on top of the left front fender well, while I was sticking my hand through to position the motor mount. They weren't marked, so I stuck them back to where they looked like they came from. Do they have anything to do with the ac? I checked all the fuses, all good. Changed the ac fuse just for gp. Still, the compressor does not kick on. All other climate controls work. Fan , heat, temp dial. I think I looked at every wire connected to the motor, just in case I inadvertently snapped one when I jacked it up. Also, I pressed the pin in the low pressure hose and it was pressurized, from what I could tell. It looks like there's a bubble in the window on top of the 'can' too.
What did I miss? Is there hope to be able to fix this myself?
Thank you in advance for any suggestions.
aj1253@yahoo.com
Art
Regards,
AJ
