smelly air-con
Old Jun 29, 2006 | 12:38 PM
eddieb's Avatar
2003 clk55 amg
smelly air-con
can someone suggest a fix for really smelly air-con when first switched on.It does clear after 2 or3 minutes but is very unpleasant. read somewhere else that the condensation drip hose can get blocked - i have not seen a small puddle under the car after running it -used to on my Honda.Can anyone tell me where this hose is meant to be.
Old Jun 29, 2006 | 01:19 PM
silver_metallic's Avatar
2016 C63S,2013 C63 AMG Coupe, 2002 C32 AMG (gone but not forgotten)
You can try this stuff or go to your local Wal-Mart/grocery store and pick up a can of Lysol.
It's important to always turn off your A/C just a couple of minutes before you park your car and while still moving.
Spray the stuff into your A/C intake right under the windshield with the A/C running. Spray for about 10-20 seconds, then get in the car and turn off the A/C. Several cycles of this and most of the nasty mold will be dead.
No sign of condensation on the ground is not always a sign of a clogged drain, but if that is the case, get a tech-service manual to help you find the a/c drain vent. (usually near the firewall) and try sticking a long pipe cleaner (tobacco shop) in there.
Old Jun 29, 2006 | 03:02 PM
Jayhawk's Avatar
S500/W220/2000
I've tried this in one of my non-MB cars and it does seem to work.
