Kickdown query?
Old Sep 6, 2006 | 11:44 AM
eddieb's Avatar
2003 clk55 amg
Kickdown query?
can someone please explain if this is correct. Regardless of what speed i am doing at the time, lets say for arguments sake 50 mph, whenever I use kickdown there is quite a pause then the revs shoot up to about 6k+, engine makes a lot of noise but car does not seem to go any faster and then changes up into the next gear and rockets off. Is this normal for a (03)clk55 transmission with 36000 miles on the clock??
Old Sep 6, 2006 | 12:05 PM
NitroShredder's Avatar
2003 E500
Yes. My E500 (03) does the same. I think kickdown will always try to downshift TWO GEARS.... without overrevving (redline) the engine... so in your case.. from 50mph... 2 gears... revs it to nearly 6000 then reaches the limiter and kicks into the next gear... at that point.. you are probably over 3000 rpm and in the torque power band....
The pause is normal also... i think it's a processing thing....
Old Sep 6, 2006 | 03:00 PM
lkchris's Avatar
'10 CL550, '12 GL550
Kickdown SHOULD be accompanied by noticeable acceleration.
