Exterior door handle mechanism
So I'm thinking it is NOT the door latch itself since it does not occur when opening from the inside and does not occur when closing.
Anyone taken apart or change out their exterior door handle mechanism?
thx
1. Pull away the rubber door seal in the area of the handle.
2. You will see a small hole, if you look in the hole, there's a 4 mm Allen screw holding the small section of the door handle with the infrared receiver. Loosen the screw (don't worry, it won't fall out. It's a captured screw)
3. Remove the infrared section of the door handle by first pulling it rearward, and then out away from the door.
4. The main section of the door handle can now be removed by pulling it rearward as well, and then out.
