Engine Codes P0700
Old Jan 18, 2007 | 09:50 AM
320clk978's Avatar
Engine Codes P0700
Went to autozone yesterday to get my car codes read. I have 3 DTC code,
P0400 - EGR VALVE
P0500 - VEH SPD SENSOR
P0700 - TRANSMISSION CONTROL SYSTEM MAL.
I was wondering what the "Trans control system malfunction" might be. Would I have to take it the dealer to get the read? Do you think I would need to get a new transmission?
Old Jan 18, 2007 | 11:11 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
I don't know which code reader/scanner AZ uses, but all those codes are high-level codes and don't tell you anything about the sensors that are causing the problem. For example, the wheel sensor code should also include a lower-level wheel sensor code telling you which side of the car or which sensor is showing a problem.
BTW, most readers/scanners can't provide any info on the MB Transmission Control Unit (TCU) and this would require a dealer/independent visit.
Regards,
paul...
Old Jan 18, 2007 | 08:45 PM
C32AMG/02's Avatar
PO700, Means the TCM has a stored in memory transmission fault code.
Old Jan 22, 2007 | 04:54 PM
320clk978's Avatar
would i have to go to the dealership to get the codes for the transmission read? or could an indy shop handle this?
Old Jan 22, 2007 | 06:11 PM
mleskovar's Avatar
'17 Jaguar XF
Why did you have the codes read (symptoms)? Did you clear the codes and see if they returned?
Old Jan 22, 2007 | 07:54 PM
320clk978's Avatar
I had the codes read at autozone, there were lights popping up like the abs bas light and check engine. I had them checked out and they gave me these 3 codes.
p0400
p0500
p0700
I found the first two, but I dont know what is wrong with the transmission. It seems like when I hit the gas to much, it would stay in second gear. Then when Im at a stoplight and go to hit the gas, it would rev to 2500rpm and then start going, once this happens, it would stay in gear and will not shift.
I hope you get what im trying to say.
Old Jan 22, 2007 | 08:26 PM
C32AMG/02's Avatar
You will need more information then fault codes if you are going to diagnose the cause of the fault, a copy of all adaptation values are also needed. If your independent tech has that capability then go to him, if not go to your dealer, you what a print out of all module codes and all adaptation values.
Old Jan 22, 2007 | 10:14 PM
mleskovar's Avatar
'17 Jaguar XF
Answer the questions please. If you ask for advice and don't answer the questions then you're on your own......if you don't think the questions are not appropriate then give a reason.
Old Jan 23, 2007 | 01:16 PM
320clk978's Avatar
Oh sorry, I did try to clear the codes, I also had O2 sensor come up but I cleared the code and that went away. The other 3 stayed. Sorry for not answering the question
Old Sep 17, 2010 | 09:30 PM
oleg1474's Avatar
2000 Mercedes ML320
Please help me my codes P0700(TCSM) and 147(ETC6)
