Mercedes Diagnostic systems
I am hunting around for some diagnostic systems and there appear to be 3 main types -
MB interface for carsoft
MB interface with multiplexer for carsoft
STAR diagnostics
WHAT THE HELL IS A MULTIPLEXER?
LOL
Such an annoying name, but anyway, what on earth is the difference between the three, as the price seems to vary alot. The first 2 appear to be the same no?
STAR diagnostics
LOL
STAR diagnostics
LOL
STAR diagnostics
LOL
The multiplexer reads all the K lines at once you can see the live data. Look at events and stored codes.
One side of the multiplexer connects the cable that plugs into the car the other plugs into a laptop.
With out the multiplexer you would need a bracket box and can only read one line at a time.
1978 280CE & 1997 SLK230 Kompressor
I have a Carsoft 7.4 Interface and use a Multiplexer Selector plug to access the different pin for each system........works very well on my Australian 1997 SLK 230K with a 38pin diagnostic plug
Doing a complete scan with an automatic Multiplexer takes quite a long time......over 40 minutes and can flatten your battery....with disastrous consequences
In version 7.4 all systems are not accessed at once, but sequentially......a long and drawn out process where every type of module is checked for and if not present the the program moves on to the next
The big advantage of the Multiplexer is that it automatically picks the correct pin to access and is a necessity if you want to do a complete scan........this would be the only model to get for an Indy working on several different MB models......but for an individual owner working on his own car a Multiplexer is not really necessary
I have a manual selector plug....once you know which systems your particular model has then you just perform the required tests and select the pin first.....takes less than half the time and really very easy once you work out which pin is associated with which test
The cheapest option for those with a 16pin OBD11 plug is to use a breakout box to access the various pins..........nothing to go wrong (no electronics) and cheap....you should be abe to get an interface and breakout box from China for ~$US150 delivered.....possibly also available in the US on eBay if you are not game to deal with China
Hope this helps
David
Hope this helps
David
This is the interface that I have........but you should be able to get it for half the price shown if you get it direct from China................
I note they promote the unit as working on all engines up to 2005......this is not correct.........seems ~2003 is the cut off and I have not heard of anyone having much success with accessing the other systems with the OBD11 connector..........the 38 pin connector works much better with Carsoft 7.4
David
