4-Matic problems
Old Jan 28, 2007 | 07:25 PM
Ken Evans's Avatar
4-Matic problems
Have 93 300E 4-Matic that does not kick it when needed. Transmission seems fine. 4-Matic light on dash stays on all the time. Is there some type of relay that could be bad? Any info appreciated. Ken
Old Jan 28, 2007 | 09:43 PM
C32AMG/02's Avatar
The light on with the key on could be an electrical or hydraulic malfunction. For electrical you can perform an impulse code read out with a home made tester, with parts bought from radio shack. Do an online search for parts needed about $25.00
If no electrical codes are found, the malfunction is Hydraulic; the diagnostic is more involved, no impulse code read out for a hydraulic malfunction, pressure gauge and a manual. The 4 Matic transfer case is very complicated to diagnose.
As a side note all 4 tires MUST be the same Brand and have the same tire pressures, no worn tire for the system to work properly.
