help TECHS with ML320 crazy
Old Feb 8, 2007 | 05:53 PM
gingar333's Avatar
Wink help TECHS with ML320 crazy
:I need help to know how can fixed the started error display message in the SUV ML320 turn on a little then turn of and send the messageThanks
Old Feb 8, 2007 | 07:28 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Could be a bad key, try your other one. If that does not do it could be lots of other things that require a dealer's attention. Like a bad ignition lock not recognizing the key or the computer itself.
Old Feb 11, 2007 | 12:27 PM
SMARTSSUCK's Avatar
Not an easy fix unless you have the diagnostic equipment, I recommend
trying the master key, even if all the other remote keys dont work the
master key will work if it is just a key problem. If the master key doesnt
work take it to a dealer.
Old Feb 11, 2007 | 05:32 PM
f4i 954's Avatar
2009 e class 2012 ml350
Does the car start?
does it start & stall?
If it`s not a key problem i think you are going to need a new das control module (N73/1).
