Help with A/C on 99 C43
Thanks, Brian!
outside temp shouldnt have a real big factor on brake fluid levels...often the fluid level drops with low brake pads (pads getting close to worn)...
just by reading your brake fluid problem im more inclined to say the brake fluid level sensor may have issues.
as far as checking a/c on a b service...well turn on the a/c to see if it blows cold...if it does its ok, if it blows warm, we note what we find.
there could be other issues with the a/c that could cause it not to come on...
you need to get it properly diagnosed....if you cant find the service port on the a/c well...ask yourself this...do you really know what goes on with an a/c system...??? those r134 charge cans with the gauge isnt the best way to charge the system..unless you know what you are doing..
like i said there are several variables that can cause the a/c not to blow cold....you can charge it with the 134 if you wish and you may be lucky and get the a/c to work...but if you have an evap temp sensor go out...bad clutch etc on the a/c that could also be the problem...i dont have the car in front of me to properly diagnose it..i can only offer my advice
as far as b service go for checking a/c its not required on the checklist...but if you have a tech that actually checks everything out on the car..hell probably do what i do and just have the car running and check the a/c cooling by turning it on and feeling the air from the vents
