I got some check engine codes...
A w124, w202, and a few bimmers
So, after not getting a response in the w202 forum, I thought I would post my codes here. Hopefully somebody out there can help me. I have a 2000 c230k.
P0105-Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P1519- Idle Air Control Valve Circuit Failure
Guys, I pretty much have no clue as to whats wrong. My car is idling like a truck, so I am inclined to think its an Idle Control Valve, but whenever I go looking for one on an autoparts website, there is no listing. Is there even an ICV? I was also thinking maybe an MAF, but I'm not sure.
PLEASE, PLEASE someone help me. I don't want to take my car to the mechanic. (My ego would suffer, haha)
Thanks so much in advance guys!
Zerodynamic
Zerodynamic
The MAP is different than the MAF so I'm not sure that a Mass Air Flow sensor will help you out. This sound like a vacuum leak in the intake, possibly near or at the IAC valve. (Assuming there is one...) Might want to check all of the air/vacuum hoses leading to the intake manifold area for cracks or loose connections. Sorry to be vague, but I'm not familiar with the c230 series...
So what is an MAP? I have never heard of it. When I get my shop manual in, I'll inspect the vaccum lines.
MAP is Manifold Absolute Pressure. It is a pressure sensor inside the manifold, closer to the cylinder ports. The MAF is the Mass Air Flow sensor and it measures the amount of air coming into the engine, (Grams/Min) usually just past (or in-board) of the air filter. MAP will generally be at a vacuum which should correlate with the engine RPM and, yeah, actually the MAF reading for air coming in... There could be something to the MAF being bad, but I'd get a code or something before buying one I think...
[QUOTE= PLEASE, PLEASE someone help me. I don't want to take my car to the mechanic. (My ego would suffer, haha)/QUOTE]
sometimes you just have to let your ego suffer and take it to a MB tech...
dont just start throwing parts at the problem..have someone look at it...
[QUOTE=fixbenz;2073326]
Well, I am going to wait for my shop manual to come in.. if I can't figure it out, I'll have my buddy who is a BMW tech take a look at it... (he helps me maintain my other cars---all bimmers! flamesuit on) If that doesn't work.. well I guess I'll take it to my indy. I'll look at the vaccum lines, thanks guys!
Originally Posted by PLEASE, PLEASE someone help me. I don't want to take my car to the mechanic. (My ego would suffer, haha)/QUOTE
