info on bi-xenons...there is something fishy there
Thanks.
Paul
Last edited by phjbbu; Mar 12, 2007 at 10:52 AM. Reason: forgot to select email notification of responses
some dealers WILL NOT do this conversion..some will...but out of courtesy for the tech who works on the car get the warning stickers under the hood
for the xenon light warning....
those xenon ignitors put out 25,000 volts...
i have done 1 conversion, but the customer already had the headlight assemblies installed..so i charged for reprogramming
if you are going to convert..use MB headlight assemblies
you never told us what car you have.
WIS will only tell you how to remove the headlights...but you need the MB SDS to reprogram the car
Paul
Now, for a few dollars more (how much, I don't know...I've made an inquiry just now and am awaiting a response), one can opt for bi-xenons so that low and high beam both work. That seems to make sense. Have a true set of burners up there (not just xenon gas bulbs) and maintain everything else stock. It seems like an elegantly simple and effective solution. What am I missing?
I am so new to the Benz world that folks have been referring to the SAM in this thread on xenons and I have no clue what that is nor how it relates to the slk's headlights, but I am a licensed professional engineer (mechanical) and I do have a doctorate, so I guess I am teachable if you all are patient with me :-)
BTW: I've also asked the seller if there is a version for the r171's in addition to the one for the r170's in the auction listing.
Paul
Paul
I could be wrong, but I am not aware of a Bi-Xenon for the SLK. I thought that they only had regular xenon, but someone who knows more may chime in on this one.
The SAM or Signal Acquisition Module is what people are referring to. In the SAM there is a setting for Xenon that needs to be set to present for Xenon lights to funtion in the correct manner.
Bottom line, stick to OEM on upgrades, you will be happier in the long run.
Many people who do OEM conversions skip these steps, and the lamps work fine, but you might dazzle oncoming traffic. Most dealers will not do it because of the liability if someone should get hurt, and the car did not comply with FMVSS 108 or the relavent European directive.
For me I don't see the advantage. I see just as well with them, as without. The Bix is a wee bit "whiter." As an $ 800 package option on a new car it might be worth getting for the "gee, golly" factor. On the other hand, to pay about $ 3,000. for OEM parts (plus the bumper!!!) is a bit steep.
Aftermarket units should be left alone. None has ever passed even the most cursory glance concerning safety or performance. Better to take the cash to Vegas, put it on red.
I'm aware of. I've done 5, to-date. What we've done is to take Depo (Taiwan)
headlights, removed the clear outer lens, tossed the poor Depo designed [sic]
halogen projector, and fitted in E55 or RS6 HID bixenon projector into the Depo.
Shy of buying OEM HID, this...i opine...is the proper way to get HID into your
car with quality. The worst thing you can do is to toss in an HID kit. These
projects are done mostly for W210 given their inherant ease of retrofitting.
p.s. the nice thing about this retrofit is that when the bix shutter is activated,
it put out one helluva full beam....and the H7 high beam compliments that HID
as well (well, as much as it can).
