99 230 Kompressor SuperCharger Rumble
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
I have the normal engage and disengage clicks from my Supercharger but am now getting a low grumbling from in the area ....which is gaining in volume at idle. Has anyone ever done maintenance to their supercharger and if so how do I get to it to take a look at the clutch and assembly. I would like to change the oil in the SC but am not sure how to go about it.
Any help would be greatly appreciated.
99 C230 Komp.
88,000 mi
99 C230 Komp.
88,000 mi
1991 300E
Just a possibility but if your unit is the Eaton twin screw, which I believe the K has, it could be the drive coupling within the supercharger snout. I have done two Buick Riviera units which have a bigger version of the same thing and both exhibited the same symptoms. The coupling looks like a hockey puck with something like six holes equally spaced around near the outer edge. It is designed to be the shock-absorber between the drive and the supercharger "screw". It wears out over time and gets sloppy in the holes. To replace it requires pulling the snout off of the unit which will possibly require removal of the supercharger. I found the couplings on ebay for around 25-30$ for the unit on the Buicks. The dealer had told the owner the whole unit would have to be replaced with new for around $1600. Total cost to fix with gaskets, supercharger oil, coolant, coupler, etc... was around $80 but that was for the Buick.
Like I said, it is a possibility. Good Luck,
Mitch
Mitch
2005, 230, 98, 99, buick, compressor, coupler, drive, fixing, issue, kompressor, removal, riviera, supercharged, supercharger
