Rotor Turning Thickness
Old Jun 8, 2007 | 01:00 PM
TNblkc230wz's Avatar
C320 Coupe
What is the maximum safe thickness when turning rotors for a 2003 C32 front rotors and a C320 Coupe rear rotors? I've heard a lot of conflicting information about turning rotors on MBs. Never had an issue with it on Japanese or domestic cars. Need to do something this weekend.
Old Jun 8, 2007 | 01:34 PM
lxl_Jeffro_lxl's Avatar
1987 E300 TD
I think it should say right on the rotor if I'm not mistaking, at least the rotors I've turned.
Old Jun 8, 2007 | 03:26 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
I Would Recommend NOT to Turn/Machine the Rotors...When I Worked for Mercedes They Did NOT Allow that...Just replace If Worn/Lip OR Under Min Thickness...The Specs are on the Brake rotor
Old Jun 8, 2007 | 03:50 PM
C320 Coupe
Just curious as to the rational for not turning them if they are not smaller than minimum thickness?
Old Jun 8, 2007 | 05:57 PM
whoover's Avatar
'19 E63S sedan
There's no reason to. Once new pads bed in, the little microridges acutally increase braking surface. If there are serious problems (warping or cracks) the rotor needs replacing. Plus, removing any metal reduces fade resistance.
Martin
Old Jun 8, 2007 | 07:50 PM
C320 Coupe
Thanks for the info
Old Jun 9, 2007 | 12:26 AM
mleskovar's Avatar
'17 Jaguar XF
The real reason is that the rotors are so inexpensive it's not worth the labor time to machine them.
Old Jun 9, 2007 | 10:49 AM
C320 Coupe
This is what I was wondering. I can get them turned by a very experienced older guy (the only guy I let balance my tires) for 5.50 each. sure beats $125 each.
Old Jun 9, 2007 | 11:57 AM
whoover's Avatar
'19 E63S sedan
Once again, if they are not below thickness spec, not warped and not cracked, why would you replace them? I don't see how cost enters the picture. If they're in spec, just change the pads. If they're not, replace them. I honestly don't see a situation where you would machine them because of cost.
Old Jun 9, 2007 | 12:33 PM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Never turn a Mercedes Benz rotor, they are throw aways. Most last over 100,000 miles with avg use. Just replace the pads. Conflicting reports that you are getting are not from Mercedes Benz. Turning rotors is a thing of the past(real old school) no up side to it, just throwing money away.
Old Jun 10, 2007 | 11:25 PM
lkchris's Avatar
'10 CL550, '12 GL550
Your experience with Japanese and American cars has no relevance to Mercedes.
Old Jun 10, 2007 | 11:36 PM
mleskovar's Avatar
'17 Jaguar XF
Wrong. Mercedes doesn't define automobiles, but they definitely influence.
Old Jun 12, 2007 | 08:44 AM
C320 Coupe
Had to throw them away
Now I know why you don't turn them. The front rotors have about 30k miles. They were at 23.7 mm thick. Min turn is 28mm and throw away is 24mm. It's amazing how badly one set of pads chewed up the rotors. No real groves, just evenly ground down. I guess that is the price you pay for brakes that really work! The rear rotors with 46K miles where below min spec as well. Hopefully the Porterfield pads will go easier on the new rotors.
Old Jun 14, 2007 | 04:03 PM
lars's Avatar
05 CLK 500 cab
Interesting. I had a similar issue with a VW Golf. At the first pad replacement, the rotors were worn below the service limit. Thin rotors cost less and save unsprung weight, I guess, but it does seem pretty chintzy.
