HELP - AC Fuse keeps popping - SL500 (R230)
Can someone let me know why this is a problem? Should I replace it with a 30-amp? Does some kind of AC-filter needs to be cleaned or something which may be the result of the fuse popping?
I know in my home if the filters are old or clogged up then my main circuit-breaker switch will trip. Not sure if this is the same case with the SL.
I do not own a Benz, but that is just my basic knowledge with working with speakers and fuses/wires.
-Good luck!
