300 e 1987 mercedes gas 4 door
hello, i have a 300 E 1987 Mercedes and the plastic cracked approximately 1/2 inch at the very top next to the big hose and is leaking, what does anyone suggest to use to repair that plastic crack? thank you francine
I think you may have mis understood the subject of this forum section... this question should be moved to the correct forum or reposted in the appropriate eclass sedan body style...
1 Post
It changes all the time
Francine,
I applaud you for stating the year and model in question. Most people don't which is very irritating. 55fanatic is right. You should post this in the 124 chassis section, but you will need to be more specific. Plastic cracked next to the big hose isn't enough to go on. Are you talking about the cooling system? Can you take and post a pic?
Peter
Peter
