1995 Model C220 Turn signal
C230 kompressor w203
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Hi ! my 1995 C220 turn signal does not work many times. At same time hazard warning does not work either. Gets a bit tricky driving in traffic ! All other lights work. Is there a connection problem or bad part? Thanks
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Turn signal
<<Hi ! my 1995 C220 turn signal does not work many times. At same time hazard warning does not work either. Gets a bit tricky driving in traffic ! All other lights work. Is there a connection problem or bad part?>>
There is a connection between the two which is dirty switch contacts in the hazard switch. Operate the hazard switch about 50 times repeatedly which sometimes clears the problem. If you can pull the switch out, some spray contact cleaner might fix it also.
