2001 E320- Starting Problem HELP?!?!?
Old Oct 11, 2007 | 10:25 PM
2die4's Avatar
2001 e320
I am havin trouble with starting my vehicle, sometimes when i turn the key to start it, The enigine attempts to turn-over, BUT does not fire up.
Also when it does this if i do not turn back the key(to the off position) it will hold the start.
( if that makes sense)
I recently changed the CPS sensor and hooked it up to a computer and nothing showed up except for the same CPS reading?!?!
Changed my battery, filter, fuel filter, and spark plugs within the last 2 months.
PLZ guys any help is needed. Benn to a few mechanics and none of them can solve this problem. Trying to avoid paying lots of money at the dealership THX
Old Oct 12, 2007 | 01:16 AM
Mohammadov's Avatar
E200(1999)Ger.Ver.
OMG,,The same problem!!i was to write that!!that car wont fire up!!i disconnect the negative wire of battery and reconnect it,and he same still so.
i think there is a problem with service issue..plz any help for me and the guy.
Old Oct 14, 2007 | 11:19 AM
KarlBenz's Avatar
Mitsubishi Outlander 2012 AWD
Beleive you can alleviate this problem by taking a small amount of neverseize compound and coating the starter drive gear or even easier from under car is coat a small section of the starter ring gear
