Problem Starting CLK-320
Old Dec 28, 2007 | 07:58 PM
californiabenz's Avatar
CLK-320
I drive a 1999 Mercedes-Benz CLK-320 (with about 100,000 miles).
A couple weeks ago when I went to start it, I turned the key, it made the sound like the engine was starting, but then promptly interrupted itself and sort of cluncked out and didn’t start. I turned the key again, and it did the same thing. Then, I tried a third time, and it worked fine – as if there had never been a problem…
It worked fine – no problems at all – for the next couple weeks. Then this afternoon (after it had started fine in the morning), it did the exact same thing – didn’t start the first couple times, then worked fine. Now it’s starting normally again.
Anyone know what could be causing this? Is this something I should worry about?
Any input would be greatly appreciated.
Old Dec 28, 2007 | 08:14 PM
CLK-320
I should add: when it doesn’t start, it’s not like it tries and keeps trying, then doesn’t start. It almost immediately cluncks out and doesn’t start.
Old Dec 29, 2007 | 03:22 PM
MBHustla858's Avatar
maybe ur not getting enough fuel , is ur fuel filter as old as ur car?
