99C280 Sport CEL Code P0306
Old Jan 24, 2008 | 09:44 PM
99MBSport's Avatar
1999 C280 Sport
Changed out wires and plugs switched #4 Coil to #6 still getting P0306 Misfire detected at #6 Cylinder. Has compression....could it be a bad injector? I have been using some off brand 87 octane fills. Input greatly appreciated. Thanks in advance.
Old Jan 26, 2008 | 08:09 PM
epmills's Avatar
99 CLK430
Plug wires are common on those engines, try swapping with another cylinder and see if the code changes, if not, swap an injector. How do the plugs look?
Old Jan 27, 2008 | 12:29 AM
99MBSport's Avatar
1999 C280 Sport
replaced the plugs with new ones(2) and switched the coil. Wires looked good and did pass an ohms test. I am leaning towards an injector
Old Jan 27, 2008 | 01:02 AM
bicylindrico's Avatar
Good advice. Don't overlook the wires until you have swapped them. They are the most likely culprit on that engine.
