Secondary Air injection Pump
Had check engine Light on S600.. I hooked my AutoTap up to the obdii port and it said Secondary Air Injection Pump fail. Not too bad of a job to get off. Need to remove the Washer tank and tie the overflow tank back out of the way.. 3 torque head bolts 1 elec. connector and pull one hose off and its out..
Hooked 12 volts to it and it didnt run. Took it apart and the lower bearing was tight. Pulled the dust caps off the ball bearings and packed them with wheel bearing grease. It works !.. Cleared the codes with the AutoTap and all is well again..
