No cost alignment?
Alignment is ONLY EVER required if you've had an accident and suspension comonents are damaged or if suspension is taken apart for component replacement due to wear. There is NO adjustment for wear, just component replacement.
I had mine checked by my local tire shop - they owed me a favor - they couldn't adjust it because it does take special parts but MB begrudgingly performed the alignment under warranty.
I would have a good independent check it nd then bring it into your dealer with the printout.
Nevertheless the rear Bridgestone RE 050s wore out with less than 10k miles - what pieces of crap. My friendly mechanic told me that they figure if I can afford a CL55 I can afford new tires every 10k miles.....
At 6500mi you can get a free rotation.
All adjustments - doors/wipers/alignment things of that nature are covered up to 12k or 1yr.
As I recall my alignment shop did an adjustment to the front but they said the rears were out and needed special bolts or something that only a MB dealer could order. This is on a CL55 and the said the CLs and SLs were similar in this regard.
im pretty sure their response will be no,their is a method of adjustment.i will concede that all alignments are required based upon wear,bending or incorrect initial set up.
