Air cleaner replacement ML30 CDI
Any helpful techs out there care to give some instructions on replacing the 2 air cleaners on a ML 320 CDI? The spacing looks VERY tight, and I think there must be a trick to it. I didn't think Mercedes would design such a non user friendly thing. All I can see are 3 torx style screws on the air boxes that looks like they needs a special 90 degree driver to get to. Help...
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
The left side is the "tricky" one and the "trick" is referring to WIS procedure AR09.10-P-1150GZB, which you can download by subscribing at http://www.startekinfo.com
Your preliminary procedures are remove engine compartment sealing and remove partition wall. 2 bolts, 1 clamp each side.
Thanks, I will look at the website... Wonder if a fabricate a cold air kit of some sort. Used to do that sort of thing in my old job. Would make life easier. Thanks again.
