reverse issue???
the dealer says this is normal and all of them have it (w220). not true cos i drove other similar cars (4 ltr diesel, w220) and they did move when in "r".
is this something i should worry about? thnks in advance!
btw: the cars i drove yesterday were 2003 and 2004 (the facelifted model)!!!
If you're talking about moving without touching the throttle then it may not move due to the low idle of the diesel engine and heavy vehicle.
Check it in both S and W (or C). But you must move back to N or P before switching tranmission modes, otherwise it won't change. These transmissions have 2 reverse gears.
I'm not sure about the W220 but at least on the W221, the gear ratios and the rear differential are the same for S500(550) and the diesel models. Assuming the same torque converter too, then all cars should behave the same when stationary if they have the same idle rpm (which probably is pretty much the case).
At least my car changes between S, C and M without selecting N in between, are US cars different?
Not sure if W220 would have the hill assist feature too but this should not make cars different.
Okay, thanks again!
