Rough Idle, Delayed Acceleraion With 2000 ML320
Yes, as much as I hate to admit this, I am having a hard time getting the right solution for my SHAKING ML320!
This past weekend, my CEL went on and at the SAME time, I began experiencing a "Rough Idle" and "Rough" Acceleration at 15,000-20,000 RPM's.
I experience the troubles especially when:
1. Coming to a stop.
2. Accelerating from a stop.
3. In the "Drive" gear at a stop.
I have a Code Error: P0305 ("Cylinder 5 Misfire Detected")
Today I changed my spark plugs for Cylinder 5.
Yesterday, before changing them, I could not get the usually "Rev" and tough accereration when punching the gas. Today, I get the Rev, but at 45,000-50,000 RPM, there is an extremely DELAYED gear change.
My problems no longer exist when I am in "Park" and when I drive greater than 25 MPH and under 15,000 RPM's, but the above problems are still existing.
Even though traditionally a worn MAF would affect more than just ONE cylinder, I still cleaned it out with MAF cleaner and NO RESULTS!
So now I am left with these possibilities (however, in other posts, they don't seem to improve the situation with the "Rough Idle"):
1. Change Spark Plug Wires
2. Change Spark Plug Coils
3. Change O2 Sensor (But I still think it would affect more than 1 Cylinder)
4. Change Fuel Filter.
I am getting frustrated, I know this probably isn't as tough of a problem for the more knowledgable MB tech, but any direction to keep me away from the STEALERSHIP will be greatly appreciated. Thanks for understanding and for any assistance!
1 Post
07' E350, 71' DATSUN 510
Try swaping cylinder #5 coil and wires with other cylinders and see if the missfire follows the coil or wires. I see wires go bad a lot more than I have seen coils or plugs go bad.
p.s. You might want to edit the 15 thousand to 50 thousand rpm to 15 hundred to 5 thousand rpms, before you get "flamed".
