BAS
Old Jun 5, 2008 | 02:05 PM
forkliftman's Avatar
BAS
I have a '99 E320 and the BAS indicator just came on while driving. What is this and can it be driven until taken care of. I do not see any difference in driving.
Old Jun 5, 2008 | 02:42 PM
OLDSCHOOLRICE's Avatar
07' E350, 71' DATSUN 510
BAS is brake assist. It senses when you might have a panic stop situation and assists by allowing quicker activation of the brakes by allowing more power assist from the brake booster.
It can be driven, but you might wish you hadn't if you end up in a panic stop situation and only need a couple more feet to stop the car.
Could be something simple like a stop lamp switch or a pressure sensor. The more extreem side of the possible repair would be a brake booster replacement due to a bad travel sensor.
Good luck.
Old Jun 5, 2008 | 07:36 PM
epmills's Avatar
99 CLK430
Majority of the time its a stop lamp switch, an easy repair if its that. Hard to say though unless you have a fault code.
