Issues with Tall tires, ie 245/45/18 e-classs?
Old Dec 17, 2002 | 02:38 PM
ricoh64's Avatar
'99 E 430 , '05 E500
Not that I'm planning on doing this, but I just wondered how installing taller than stock tires affects the suspension and or braking/esp system.
would just liked to know the technical reason why you should not go taller.
Thanx
Old Dec 17, 2002 | 05:41 PM
E420SportGT's Avatar
'97 MB E420 Sport/'88 MR2
If your overall diameter is bigger than stock, it will throw off your speedo.
I wouldn't go with taller height..if you're going bigger on the wheels, then the tire profile has to go lower.
Old Dec 19, 2002 | 12:17 AM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
What's the stock size it's wearing now ?
NP
Old Dec 19, 2002 | 06:45 PM
ricoh64's Avatar
stock is 215/55/16, issue is in the total dia. of 25.5". If I go into a size where the diameter goes into the 26-27" i'd like to know the mechanical implications besides speedometer adjustments. I know the ABS would be affected but how? Would ESP be affected and how would that affect be physically interpreted. In a panic situation what would happen to the abs, esp, with larger dia. tires. ex. 26.5"(255/45/18)? Would the affects be significant?
this kind of info i was looking to for ...
thanx
Old Dec 19, 2002 | 08:32 PM
Nektopoli's Avatar
----Tire------MPH70--Percent-Error----Revs/Mile
215/55R16_____70_________0_________796.83
255/45R18____74.8_______6.81________746.01
235/40R18 are a much better match. If you keep all 4 tires the same size it shouldn't cause problems with the EPS or ABS, the larger tires you want will throw off you speedo at 75MPH it will read 70MPH
NP
